Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How do I programatically change the text in a listbox that is contained in a cluster?
sfrosty
Active Participant
06-19-2002
10:59 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
0
Kudos
Message
1
of 3
(3,106 Views)
Reply
Re: How do I programatically change the text in a listbox that is contained in a cluster?
BigBen
Member
06-19-2002
12:12 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
In the front panel, right click on the listbox object and select create>attribute node.
In the diagram click on the attribute node and select "Item Names".
Connect the desired array of string to the attribute node.
BigBen
1
Kudo
Message
2
of 3
(3,106 Views)
Reply
sfrosty
Active Participant
Author
06-20-2002
05:08 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks "BigBen". Sometimes you just can't see the forest through the trees!
0
Kudos
Message
3
of 3
(3,106 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
