Curious little bug: Tank Housing color
Has anyone tried to use Tank Housing color in the icon editor of a VI? For me, the Tank Housing color is actually the same as the Classic Object color, when it should be a kind of faded blue.
Edit: I'm using LV 8.5
Message Edited by Sima on 09-29-2008 09:46 AM
(2,826 Views)
Hey,
You might have changed the default colors under the LabVIEW Options.  Tools>Options>Colors
Christian
(2,779 Views)
Hi Christian,
I haven't changed the default colors. I also found the same thing on a fresh install of LV 8.6.
(2,767 Views)
Hey,
Now that I had a closer look on this I can see the same behaviour on 8.2.1, 8.5.1 and 8.6. I was not able to see it because I use a cusotmized icon editor, which i would suggest everyone to use, here it is: http://decibel.ni.com/content/docs/DOC-1051
However, I agree, it is a little bug what you found.
Christian
(2,753 Views)
