Vision Builder 3.5
I'm using vision builder 3.5 for product inspection. I want to know whether i can open Inspection Interface Screen as default ? And as soon as the screen opens the inspection should be in running mode ? Because the system will be stand alone, only the monitor & CPU will be provided on the line. Is it possible…?
(3,830 Views)
Hey,
In VBAI under Tools>Options>Startup you can set "Start Inspection when Launched", which causes VBAI to run a predefined inspection when you start it. So you can put VBAI e.g. into the Autostart Folder of Windows then.
Christian
(3,817 Views)
Hey Thanks... 🙂 i'll try it out & will let you know the result... 🙂
(3,812 Views)
Hey.. It worked.. 🙂 now I'm facing another problem.. Once I started inspection; at the end of day how I supposed to shutdown my system....?
(3,795 Views)
Hey please tell me how to shutdown my system without mouse & keyboard....? After inspection I need to shut down my system..
(3,730 Views)
Well, I wouldn't have used a Windows system for a headless application. I would take CVS which runs with a Realtime OS which you can simply power on, the application is running and the power down.
In your case....I don't know...switch off the system?
Christian
(3,691 Views)
