Cursor set Y-value with linked graphs, no error (BUG)
As seen here when you set the y-value of a cursor that is linked to a graph, the cursor isn't moved (since Y-values can be duplical), but this action does not return an error.
This is a bug IMHO!
Ton
My LabVIEW Ideas
(2,994 Views)
Accepted by topic author TCPlomp
Dear Ton,
I was able to reproduce this issue with a simple VI; this is reported and under investigation under CAR# 165613.
Thank you so much for bringing this issue to our attention.
Martijn S
NI Netherlands
(2,916 Views)
