multithreading
How to use multithreading in LabVIEW?
Is the attached diagram works in multithread?! what's lack? because when I tested it, it works sequentially
(4,682 Views)
Remove all the while loops and sequence structure. It will work as you expected.
Message Edited by Mathan on 05-12-2009 06:22 AM
(4,676 Views)
In the begining I did like you ve said but it worked sequentially! not really in prallel?? how to do please! especially that functions that want to execute in parallel  takes a time and cantain loops and sequences..
(4,664 Views)
For the subVI, go to File -> VI Properties -> Execution and check Reentrant execution.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,658 Views)
Perhaps your DAQ device does not accept parallel access.  If your loops were doing things which did not require shared access to a resource outside the CPU, they would probably mutlithread.
Lynn
(4,632 Views)
Oh that's a good observation by Lynn. Before you check the re-entrant option, be sure to ensure that all shared resources are protected (possibly by using sempahores).
Adnan Zafar
(4,627 Views)
Rather than letting each loop at the port seperately like you have done.
I would sugget you look at my Action Engine Nugget where I used the challenge of writting to a DIO port from multiple threads as illustrated here.
By use the AE approach the semaphore "comes along for the ride".
Have fun!
Ben
(4,602 Views)
