Curve Fitting
I want to fit a curve using an equation.
Before fitting the curve, I have to find zeros (roots) of an equation using Bisection (Dichotomy) method.
In the method I am getting wrong value
the equation is as follows
H1= HR*cos(th-tm)-4*pi*M*(cos(tm))**2;
   H2=HR*cos(th-tm)-4*pi*M*cos(2*tm);
      F = 9E9- ((g*b)/(2*h*pi))*sqrt(H1*H2);
g=2, b= 9.27E-24, h=6.6E-34
will appreciate your effort
(3,815 Views)
Accepted by learn123
Is this a LabVIEW question or a maths question? Have you written code to calculate the result of the equation and it is returning the wrong result? If so, you should post your code, some sample data and the expected result so we can try to help.
(blog)
(3,784 Views)
Thanks for your kind words.
I have solved the problem
(3,588 Views)
