Custom Enum items enable and Disable dynamically
I'm using 6 Enum controls with same items and each enum having 1. Analog-1, 2. Analog-2, 3. Digital-1, 4. Digital-2.
At any instant I have to select Analog-1 in any two controls and remaining four controls that item should be disabled.
Similarly Analog-2 in any four controls, Digital-1 and Digital-2 in any five controls.
Please help me in this implementation.
Sonti
Message 1 of 8
(7,622 Views)
"DisabledItems" property node of the enum control will do this functionality. You need some logical implementation with event control. Have you tried anything using those controls? Can you post  the VI you have tried so far?
Message 2 of 8
(7,602 Views)
I'm thinking about the logic between the Enums.
Till now no logic is impemented. Please help in this.
Message 3 of 8
(7,596 Views)
Accepted by Sonti_11532
The following code disables the Analog-1 item on enums 2-6, when on enum1 Analog-1 is selected. Still, if you would like to implement your idea this way, you will have to create some large logic.
Adam
Message 4 of 8
(7,593 Views)
Actually your VI has Ring controls not Enum. Anyway no problem with that. You can create separate event case for each control's "value change event". In each case you can use the property nodes of other controls for disabling that particular item.
Message 5 of 8
(7,592 Views)
Hello Adam,
Your disabling Analog-1 in 2-6 enums but maximum Analog-1 selections are two out of six.
How to check the Analog-1 is selected in two control or not? and similarly other items also.
Regards
Sonti
Message 6 of 8
(7,588 Views)
You could use four separate counters (since there are four enum items), and check thier values in the event case.
Message 7 of 8
(7,582 Views)
So far I tried but I didn't achive the output.
Kindly, anyone send the simple logic for for one case.
Sonti
Message 8 of 8
(7,569 Views)
