Custom Functions Sub-Palette with constants of different data types
Accepted by datatechNDT
If all you care about is type and not value, then there is a package on VIPM called GPower that might already have some of what you need. Not sure what you want for non-numeric datatypes, but they have a decent selection of constants of different numeric types, as well as the mother of all fundamental constant polymorphic VIs...
Spoiler
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 11 of 13
(484 Views)
They're missing McGregor's Constant*, defined as the difference between the expected result and the observed result.
Just add it onto your measurement data and boom!  Perfect results!
-Kevin P
* passed down as lore back in engineering undergrad days.  Inspired post-test remarks like, "Basically aced the test, just forgot to add in McGregor's Constant a few times."
Message 12 of 13
(479 Views)
Sadly they are incompatible with LabVIEW 2018 for whatever reason. It says "This package is not compatible with your operating system or any Labview version installed on your computer". But the tools look amaizng
Message 13 of 13
(462 Views)
