Custom Numeric Control
As I indicated in a previous post, I use PaintShop Pro (Revision 5) it's quite an old version now but I am comfortable with the user interface and use it a lot. There are many other packages available that do a similar job, some freeware. The original version of PaintShop Pro was shareware but in later years they started to charge for it.....  I don't really like the more recent versions as the user interface became a bit over complex. I seem to recall that you could download a "criple ware" trial version (www.jasc.com), Jasc were later purchased by Corel (www.corel.com).
I have (I believe) rotated the images and placed them in the attached ZIP file with th -d indicating what I believe was the down position.
Hope this is what you wanted.
Message 11 of 12
(756 Views)
Hello again Conseils!  Those buttons/pictures are exactly what I needed and seem to have done the job.  I've been busy and haven't had a chance to get back to you before, but I'm able to now.  I haven't used the control in any programs yet, but it is a nice option to have.  We have been using the control I posted earlier in the thread, with the classic arrows.  But I've attached what I ended up making with your buttons/pictures, if you want to take a look.  That was just quickly putting things together as a starting place for me.
I'll have to look into that program you mentioned as well.
Thank you again for your help with this, I really appreciate it!
Using Labview 7.0 and 2010 SP1 with Windows XP and 7.
Message 12 of 12
(734 Views)
