Custom Scale
Hi everyone,
i would like to scale an analog input channel with the following function: y = 10^x
Custom scale using polynomial does not work, because my base is 10, and not the measured value.
Any idea how this can be implemented?
Best regards
rusty21
(1,342 Views)
Accepted by rusty21
Hi rusty,
Apply the scaling using the 10^x function after the DAQmxRead...
(Out of interest: which kind of sensor do you measure?)
(1,330 Views)
Hi GerdW,
thank you for your helpful advice.
Sensor is used to determine the surface resistance.
Best regards
rusty21
(1,280 Views)
