Custom excel template path in Stanalone application
But it works fine in development computer. I guess that express .VI can't actually find the template
Is there any way for us to verify that the template has been found by express VI?
Message 11 of 16
(1,691 Views)
Try renaming the template in the \data folder and see if you get the same error.
Message 12 of 16
(1,688 Views)
Yes, The same error occurs after I renamed the template.
Would you mind to give me the list of things that I have to do to build the application that has custom excel template please?
or a sample VI will also be wonderful.
Btw, I also attached the project file here
Message 13 of 16
(1,686 Views)
Hello...
Finally I found the reason why my program didn't work...
I was just my stupidity, I forgot to set the ActiveX on and also I forgot to specify the file name in "path to save report"
Thanks though for helping
Message 14 of 16
(1,672 Views)
Accepted by topic author U_hend
I did a test project and followed the instructions in this NI help file:
Report Help
and was able to generate an Excel report successfully. However, I did NOT wire a path control to the express VI. My path to the file was already defaulted in the Express VI itself (under the "Configure Save to File Options..." button). If that is what you also did, then delete the path control.
Here is my block diagram:
and the build specification:
Message 15 of 16
(1,671 Views)
Yes...The setting was right actually Bill@NGC
It's just that when we wire the "Path to save" file, we have to write the file type (i.e C:\Documents and Settings\\My Documents\Downloads\Myfile.xls)
Thanks a lot 😄
Message 16 of 16
(1,668 Views)
