Custom map breaks when built into a PPL/EXE
Hello!
I'm using a custom map (Key: String, Value: Custom Class) the reference to this map is passed into the Main Class. After building the Library into a Packed Library I get a broken wire error on the custom map but the standard map is OK.
I think that I have tried all of the different combinations of check boxes in the Additional Exclusions and Connector Pane State properties while building into the PPL. I have also tried building into an EXE with the same error.
I have attached a screen shot of the Project (working) vs PPL (broken) and a zip file of the example code.
I am running Labview 2019 19.0.1f1 (64-bit).
Thank you for any help you can provide!
(2,350 Views)
Not really solved but my work around was to place the control in the class instead of the reference and rework my code so that I didn't need the map to update on the front panel.
I know that maps are new so I'm expecting that they just didn't get implemented/tested completely.
(2,270 Views)
