Custom signal generation analog output
How can I program a USB DAQ device to generate an arbitrary function? (I have an array of the output to be generated at all points in time)
(2,169 Views)
(2,171 Views)
Hi aniketr,
have you looked at all those example VIs coming with LabVIEW?
(It might help to exactly specify the "USB DAQ" device you are using!)
(2,149 Views)
