FlexRIO Controller Support for LabVIEW NXG
Hi
I would like to know whether NI-7935 is supported in LabVIEW NXG. I have tried to add the target in the System Designer but i couldn't find it in the devices listed. I have retried the same by installing Communications System Design Suite but couldn't find it either.
Can you please let me know whether this device is supported in LabVIEW NXG? If yes, could you please let me know the drivers to install.
Thanks and Regards
Suneel
(3,135 Views)
7935 does not show up here: https://www.ni.com/pdf/manuals/377710a.html
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(3,129 Views)
Hi
Thanks for your quick reply.
But my question is that NI-7935 is a Controller for FlexRIO which has Linux RT running in it. Basically it acts as a RT Target. I'm able to add PXI RT controllers to the System Designer but not this one. So, i have a doubt, whether i have install any additional drivers for this device or it is not supported as of now.
Thanks and Regards
Suneel
(3,115 Views)
I understand your concern.  Can you add other FlexRIO cards?
ALE Consultants
(3,106 Views)
Yes, I'm able to add.
(3,104 Views)
The FlexRIO 18.7 driver does not support NXG: https://www.ni.com/pdf/manuals/374872r.html#ades
7935 is not shown here: http://www.ni.com/en-us/shop/electronic-test-instrumentation/add-ons-for-electronic-test-and-instrumentation/what-is-labview-fpga-module/compare-labview-fpga-module.html
In short it does not look like the 7935 can run in LabVIEW NXG 3.1.
ALE Consultants
(3,084 Views)
Yes, Looks like NI-7935 isn't supported.
Anyways, Thank You Terry.
(3,064 Views)
