Custom tick label intensity graph
Is it possible to assign custom tick labels to the y-axis of a intensity chart?
The background to this question is that I stack multiple spectrograms side by side in that chart, thus making a repeat of the y-range necessary.
(3,872 Views)
Hi Schorsch,
basically you can change the style of the ticks (check the screenshot at the attachment) of the axes.
Moreover you are able to change the appearance of the label like mentioned in following link:
How Can I Customize the X-Axis Labels On My LabVIEW Graph/Chart So They Appear Vertically?
http://digital.ni.com/public.nsf/allkb/1F7C1B089E45908E86256C8C0051894A?OpenDocument
But so far you aren't able to create several y-axis for an intensity chart.
Cheers
RupiDo
(3,703 Views)
