Customizable dialog box
Hi everyone,
I’m looking for a VI that implements a dialog box with these options :
 - configurable buttons (OK, OK/Cancel, Yes/No, Yes/No/Cancel...)
 - selectable dialog appearance (Standard, Critical, Question, Exclamation, Information)
 - modal or non‑modal execution
 - synchronous or asynchronous call
 - optional automatic closing after a configurable timeout
 - compatibility with both 32‑bit and 64‑bit versions of Windows and LabVIEW
Any suggestions or shared VIs would be greatly appreciated.
Thanks in advance!
Message 1 of 16
(2,283 Views)
I made an Express VI that's a "Universal Dialog Box", but the available configurations are different from yours.
Message 2 of 16
(2,237 Views)
Thank you for your answer.
Which configurations are supported?
Would you be willing to provide it to me (via private message)?
Message 3 of 16
(2,233 Views)
Maybe he is referring to
https://forums.ni.com/t5/LabVIEW/Universal-Dialog-Box/m-p/4205270#M1218026
or
https://forums.ni.com/t5/Example-Code/Universal-Dialog-Box/ta-p/4375400
Message 4 of 16
(2,225 Views)
or
Those are old.  I have a newer version.   I'll post it later today.
Message 5 of 16
(2,206 Views)
Thanks in advance!
Paul might just provide a good solution for a reasonable subset of your requirements.
I assume you are looking for a dialog subVI that has these options as inputs.
Synchronous vs. asynchronous has to be decided by the caller, so you would need an additional wrapper, especially also if you want it asynchronous and disappear after a given amount of time. How are you planning to get the return value in the asynchronous case?
Should it be reentrant so you can use multiple instances? If not, it could be implemented as an action engine that can show/hide its panel based on inputs, return immediately, but keep the panel open if needed. It would remain open until the next call where it would act according to the new inputs. It could even display a timestamped log of the last few calls to it.
Note that the stock 3-button dialog is actually a set of VIs that you could use as a starting point.
(as long as you do it all in LabVIEW, bitness is irrelevant)
Message 6 of 16
(2,197 Views)
Thanks in advance!
Reentrancy shouldn't be a problem.  Each instance of a call to an Express VI is inlined:
When you drop an instance of an Express VI, a copy of the original instance is placed inside the SubVI object that's on the BD.  Then the configuration VI runs and modifies that hidden copy.
Message 7 of 16
(2,172 Views)
Well, for what it's worth, here are versions 3.1 and 3.2.
3.2 is broken because I haven't finished the localization support.
Message 8 of 16
(2,168 Views)
I meant that a non-reentrant might be a good solution, e.g. if a single instance would popup, adding to a list of recent alerts, each call behaving as wired and return a button or just keep the panel open.
Message 9 of 16
(2,160 Views)
Thank you for the information.
Has anyone experimented with .NET calls or DLL calls? We have VIs of this kind that work in 32‑bit, and we now need to adapt them to 64‑bit.
In this context, I’m browsing this forum to see whether there are any useful ideas to pick up.
Have a good day.
Message 10 of 16
(2,015 Views)
