Customize Graph Palette buttons
Is there a way to customize the Graph Palette buttons in a XYGraph with LabVIEW 8.2.1?
I'm able to select and customize the cursor movement arrows (I imported two customized images for the ON and OFF state, for example);
but when I select in the same way the Graph Palette, or one of its buttons, the Edit --> Customize control... option is disabled
I've already customized most of the other graph parts, and now the Graph Palette looks poor Smiley Sad
Thanks in advance
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,967 Views)
Accepted by topic author vix
Seems to work OK if you place the entire graph into customize mode and simply right-click on the palette buttons to import your graphics. try it! 🙂
(3,956 Views)
