Program driven events
Hi
how can I make a value change event to react both to the user changing the value and the program changing it
thanks
shai
(3,416 Views)
You can write to a value(signaling) property of the control to programmatically trigger the associated event.
(3,415 Views)
Can you add an example? Because IM not sure I understand what you mean.
shai
(3,381 Views)
Here's a simple example (LabVIEW 8.0), see if it makes sense.
(3,377 Views)
