Customize array: no frame
I'd like arrays without a frame, i saw some people did it but i don't understand how. When i go to customize mode, the frame can't be resized or painted. If i click it, the whole control gets selected (LV 8.6)
(3,818 Views)
Accepted by Snamprogetti
Hi Snamproge...,
use the classic array container, there you can hide the frame with a transparent color.
Mike
(3,813 Views)
Please give me please code's example for "hide frame with transparent color".   I need array with no frame (decal).
(3,722 Views)
Just use the coloring tool as described. The tranpsarent color is the "T" in the upper right of the palette. Use the spacebar to toggle forground/background color.
Where exactly do you get stuck? (If you want an example, let us know your LabVIEW version.)
(3,685 Views)
