Customize indicator
I'm looking for an indicator, like the Tank indicator but with two visible limits. The limits would be program controlled an may change from time to time.
Any idea on how to solve this?
(3,210 Views)
Try right clicking on the tank indicator and se~lect Add Slider.
Hope this helps,
Paulo
(3,203 Views)
Hi Wakeguy
I've attached a VI that uses a tank with 3 sliders. One for the level and two for the limits. The limits use a "No-Fill" fill style if you check the control's properties and have been set to black. All three are in a loop just to show how they can be altered dynamically. VI is version 7.1. I have noticed problems when changing the slider colours which could indicate a LV problem with this control.
Hope that helps
Neil
(3,197 Views)
