Customizing context help
I have created a standalone executable for my LabVIEW application. I want to know whether it is possible to customize the context help so that it appears only in Spanish (even the title bar) in the final application.
I appreciate any help you can provide.
Enrique
Madrid - Spain
(3,180 Views)
I believe you can use the export setting and import setting. They are available from the menu: Tools >> Advanced
-Joe
(3,161 Views)
You can learn more about this topic by reading the application note called "Porting and Localizing LabVIEW VIs". You can get to this note by opening online help, Contents, Related Documentation. The topic with the above name has a link to the PDF.
There's also a nice (highly rated) article online - Localizing your LabVIEW application to different languages - Tutorial - Development Library ...
Roy
(3,144 Views)
