Does anyone know about a VI for the NI USB-9211 thermocouple DAQ?
I just bought a USB-9211 from NI. It works fine if I run the VI, executable, that comes with it. However, I would like to change the LabVIEW code to play with the temperature data that I am collecting, but since the CD came with executables only, I can't access the code. I have never collected data from a USB-port before, so I guess if I had a code that would allow me to collect the data coming into the USB port, that would help me a lot. Does anyone know of a code I can use?
-jc
(2,767 Views)
Hello jc,
If you click on the following link, it should take you to some example code written for the USB-9211. In the zip file there should be a VI as well as an executable. I'm assuming that the executable is the same one that you have seen. However, the VI should show you how to use the DAQmx Base driver to do thermocouple measurements with the USB-9211.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=ECF5A8CCAA164657E034080020E74861&p_node=201210&p_source=External
Hope this helps!
Take care,
E.Lee
Eric
DE For Life!
(2,755 Views)
