Cut from 2D array
It's easy to cut a specific part from 1D array.. using the delete from array function or subset array.
But how can I Cut from 2D array!!
for example the hatched part of the attached photo
(4,436 Views)
Array Subset will work with 2D arrays.
You'll need to set the row index, number of rows, column index and number of columns.
For the example you give, that might be something like "225, 15, 0, 2". If you leave any unwired, you'll get all of that thing (so you could also in the example above just wire "225, 15" and leave the column index/length unwired.
(4,419 Views)
It still not possible for me,
I have attached my code and the data file.
I would like to cut for example 100 value from the output file and write it in anew output file.
can you check !!
(4,413 Views)
Accepted by Khallod
Well, in your VI I see the 2D array just before the Write Delimited Spreadsheet call, but there's no Array Subset connected to that wire.
If you'd like to write a second file with a subset, you can branch that wire, connect it to the Array Subset function, and wire the appropriate values.
Something like this, maybe?
(4,403 Views)
thank you,
But I already solve the problem as the attached
(4,395 Views)
