Cycle through an array
LabVIEW 2013
Attached is the browser program I am working on. I am trying to cycle through the database elements that are displayed in the cluster by means of a boolean button. Any help would be hugely appreciated
I have not lost my mind, it's backed up on a disk somewhere
(3,422 Views)
This is technically a duplicate thread:http://forums.ni.com/t5/LabVIEW/Sequence-through-a-cluster/m-p/2837814#M829070
(3,398 Views)
You are already doing it with the array of paths for the pictures.  Just do the same thing for the array of clusters.
(3,395 Views)
Accepted by PauldePaor
Hi Paulde,
Are you having trouble with any specific aspect of achieving this functionality?
I have created a quick example that may be of use to you.
https://decibel.ni.com/content/docs/DOC-36661
Cheers,
Tim, CLD, CTD
National Instruments (UK & Ireland)
________________________________________________
"No problem is insoluble in all conceivable circumstances"
(3,359 Views)
