DAQ Assist to block diagram code
I am fairly new to NI Signal Express.
I am using the NI 9214 for thermocouples and I have sucessfully communicated with the NI using DAQ assistant.
It generated the code below.
How can i have more control of my VI?
I want to be able to turn on and off my CHANNELS
i want to have graphs, etc.
can i expland the DAQ ASSISTANT ICON to something with more control?
thanks in advance.
Message 1 of 26
(5,762 Views)
YES!  right click the DAQ Assistant select "Generate code"
Message 2 of 26
(5,743 Views)
yes...
thats what i thought would happen before too but i am using version 2014 and it doesnt show?
Message 3 of 26
(5,732 Views)
Accepted by super_saiyans
Hi saiyans,
reading the LabVIEW help may give you the advice of selecting "Open Front Panel"…
Message 4 of 26
(5,722 Views)
Use the Open Front Panel to transform the Express VI into an actual VI.
Message 5 of 26
(5,717 Views)
Open your Task manager and ensure process "mxssvr" is running
What is the device- (this is a newer feature) what version of DAQmx?
Message 6 of 26
(5,711 Views)
are you guys using 2014?
i dont see any of the suggested ideas on my labview
i am using daqmx 14
Message 7 of 26
(5,704 Views)
Open Front Panel is in your screenshot.  Use that.
Message 8 of 26
(5,696 Views)
hmm...?
Message 9 of 26
(5,689 Views)
Oh, you already opened it.
Well we don't know what you want to do.  Since you have a real VI to work with YOU need to decide how you want to enhance it.  I would start with changing some of the constants on the block diagrams to controls.  You can drop a chart on your front panel and wire DAQ out data right to it.  If you get stuck, be specific about your goals and post your newly opened VI.
EDIT:  BTW, if you want more help I suggest you use File > Save for Previous Version... and make it a 2013 or 2012.  Many of us who could help out still haven't upgraded to 2014.  Smiley Wink  I saw that you wanted channel control and graphs but I can't open your code.  Smiley Sad
Message 10 of 26
(5,683 Views)
