DAQ Assist
In my case, what would happen, If I download and update NI DAQmx with version 9.8. Will it affect my previoius setup ? If yes, can I revert back to my old set up.
I have downloaded the file and extratcted too. Just waiting for your response.
Chethan
Message 21 of 30
(1,628 Views)
ok sure. according to compatibility chart. 2012 LV supports 9.8 too. Which Shall I select either 9.5 or 9.8.
please tell this. So that I can start updating and will post if I face any issues
Chethan
Message 22 of 30
(1,627 Views)
So can I update NI DAQmx with 9.5 or 9.8 version for LV 2012 ?  suggest me
Chethan ?
Message 23 of 30
(1,627 Views)
Personally, I would install the latest version. Since 9.5 isn't listed as being compatible, why are you even mentioning it?
Message 24 of 30
(1,624 Views)
Thanks. I will install 9.8 version. One question, Should I need to unisntall the old one before I Install the new version ?
Is there different procedure to update DAQmx ? Just installation steps, right ?
Chethan
Message 25 of 30
(1,616 Views)
That's not the latest! And no, you don't have to uninstall the old one.
Message 26 of 30
(1,611 Views)
The new should install just fine over the old.
If I was going to install an older version than what I had, then I think I'd have to uninstall the new in order to be able to install the older version.
Just drop the DVD in the drive and run setup.  Or download the drivers from NI's driver download page and run the setup.
Message 27 of 30
(1,609 Views)
David, Ravens, NI team
Thank you so much for help. Re-complied and rebuilted VI'S with 2012  again. Then installed and updated it with compatible version of NI DAQmx.
Now its working, and we are able edit DAQ assistants.
Thanks for support.
Chethan
Message 28 of 30
(1,597 Views)
I'm glad to hear.  Good luck in ringing out the code and taking care of anything else you come across in the process of upgrading.
(Not sure who David is.  I assume you meant Dennis.)
Message 29 of 30
(1,589 Views)
Yes. Its Dennis. I am sorry.
Chethan
Message 30 of 30
(1,579 Views)
