03-19-2015 09:57 AM
In my case, what would happen, If I download and update NI DAQmx with version 9.8. Will it affect my previoius setup ? If yes, can I revert back to my old set up.
I have downloaded the file and extratcted too. Just waiting for your response.
Chethan
03-19-2015 10:00 AM
ok sure. according to compatibility chart. 2012 LV supports 9.8 too. Which Shall I select either 9.5 or 9.8.
please tell this. So that I can start updating and will post if I face any issues
Chethan
03-19-2015 10:01 AM
So can I update NI DAQmx with 9.5 or 9.8 version for LV 2012 ? suggest me
Chethan ?
03-19-2015 10:23 AM
03-19-2015 11:03 AM
Thanks. I will install 9.8 version. One question, Should I need to unisntall the old one before I Install the new version ?
Is there different procedure to update DAQmx ? Just installation steps, right ?
Chethan
03-19-2015 11:09 AM
03-19-2015 11:10 AM - edited 03-19-2015 11:11 AM
The new should install just fine over the old.
If I was going to install an older version than what I had, then I think I'd have to uninstall the new in order to be able to install the older version.
Just drop the DVD in the drive and run setup. Or download the drivers from NI's driver download page and run the setup.
03-19-2015 01:10 PM
David, Ravens, NI team
Thank you so much for help. Re-complied and rebuilted VI'S with 2012 again. Then installed and updated it with compatible version of NI DAQmx.
Now its working, and we are able edit DAQ assistants.
Thanks for support.
Chethan
03-19-2015 03:37 PM - edited 03-19-2015 03:38 PM
I'm glad to hear. Good luck in ringing out the code and taking care of anything else you come across in the process of upgrading.
(Not sure who David is. I assume you meant Dennis.)
03-20-2015 07:11 AM
Yes. Its Dennis. I am sorry.
Chethan
