‎03-24-2008 11:36 AM
‎03-25-2008 07:05 PM
‎03-25-2008
10:43 PM
- last edited on
‎05-02-2026
10:30 AM
by
Content Cleaner
‎04-09-2008 10:28 AM
‎04-09-2008 10:29 AM
‎04-15-2008 06:18 PM
Hi bgg,
The DAQCard-6024E supports the DAQmx drivers; therefore you should be able to develop your application using this driver. I understand that you are using the extended I/O cable instead of the MIO suggested in the knowledge base. So far, I don’t see any reason why it shouldn't work, more than the fact of the cable. Can you give us information on the DAQ drivers’ version that you are using for Traditional and DAQmx? Do you see the same behavior if you use another input channel? Can you run other tasks with the 6024E and the DAQmx drivers? Is this problem only with Strain tasks?
