DAQ Assistant: Unable to setup Analogue Triggering
System Setup: Labview 7.1, PCI6224 Board, CB-68LP Interface Board.
I have set up a Block Diagram to read the voltage on two channels, I am also storing the data to represent the data in graph form using an excel spreadsheet. To capture the data I want will require an analogue trigger. When I attempt to setup the analogue trigger in the DAQ assistant, the analogue part of the menu is blanked out.
My colleague has Labview 7.0 and the DAQ Assistant has the analogue options in the trigger menu highlighted. I copied his DAQ Assistant over to my system but the analogue option immediately blanked out.
Apart from downgrading to Labview 7.0 can anyone suggest any fixes.
(2,874 Views)
Your Board doesn't support Analog Triggering. See the attached information.
http://volt.ni.com/niwc/daq/what_is.jsp
Kind Regards
Steven Bird
(2,864 Views)
Thanks Steven
(2,856 Views)
