DAQ Assistant is not installed - error message
Hello KowdTek,
I'm sorry to hear that you are still having this problem. Do you have the Visa driver installed on your machine? If you do, it will install the Instrument I/O assistant. Could you try to place one of these on the block diagram and see if you get the same error?
If it does error out the same way, I believe the problem has to do with LabVIEW scripting that it done with the DAQ assistant. In order to fix this, I would suggest uninstalling and reinstalling the LabVIEW Run-time engines on your machine. This shouldn't take to long to try.
Jim St
RF Product Support Engineer
Message 11 of 11
(311 Views)
