DAQ Assistant "No supported devices found" for PXI system
I am trying to connect a PXI system (that contains a Multifunction RIO) to LabVIEW. When I open the DAQ Assistant in LabVIEW and go to acquire signal >> Analog input>> Voltage I am getting the message " no supported devices found". Shouldn't the IO channels of the RIO be listed here?
(1,496 Views)
Accepted by Anupama07
Hi Anupama,
usually RIO devices don't provide DAQmx functionality.
So why do you expect the DAQ(mx)Assistent to handle your RIO device?
(1,492 Views)
RIO stands for Reconfigurable Input Output. It is FPGA programmed using NI-RIO driver, not via NI-DAQmx.
https://tmesystems.net/
(1,470 Views)
Ok thanks. Is there any user manual or tutorial for learning about this?
(1,462 Views)
(1,460 Views)
Hi Anupama,
search for LabVIEW+FPGA basics tutorials…
(1,428 Views)
LabVIEW FPGA Getting Started
(1,401 Views)
