DAQ Assistant "No supported devices found" for PXI system
I am trying to connect a PXI system (that contains a Multifunction RIO) to LabVIEW. When I open the DAQ Assistant in LabVIEW and go to acquire signal >> Analog input>> Voltage I am getting the message " no supported devices found". Shouldn't the IO channels of the RIO be listed here?
(1,580 Views)
Accepted by topic author Anupama07
Hi Anupama,
usually RIO devices don't provide DAQmx functionality.
So why do you expect the DAQ(mx)Assistent to handle your RIO device?
(1,576 Views)
RIO stands for Reconfigurable Input Output. It is FPGA programmed using NI-RIO driver, not via NI-DAQmx.
https://tmesystems.net/
(1,554 Views)
Ok thanks. Is there any user manual or tutorial for learning about this?
(1,546 Views)
(1,544 Views)
Hi Anupama,
search for LabVIEW+FPGA basics tutorials…
(1,512 Views)
LabVIEW FPGA Getting Started
(1,485 Views)
