DAQ Assistant
Actually me and a partner are working with a research project about  photovoltaic modules and we needed a measurement equipment to collect some data and analyze it, so we chose the NI MyDAQ;
We had some problems with our routine computer and we lost the programs installed there, when we installed the programs again in the new computer we had this problem.
The DAQ Assistant is not being showed in the Express and Measurement panel of Labview. I tried to install some DAQ drivers and to update te programs, but nothing changed.
What should I do?
(2,420 Views)
Hello, DAQ Assistant isn't show up on both place you mentioned.
It will appear on
Measurement I/O >> NI DAQmx
Express >> Input (or Output)
But in your situation, I guess that it doesn't appear. I want to ask you,
- LabVIEW Version
- DAQmx Driver Version
There is a version compatibility between to software like this link.
GCentral
(2,388 Views)
