DAQ OPC server error
I have configured a DAQ OPC Server. I tried to access it through Server Explorer, but
In INTERFACE properties of DAQ OPC Server only IOPCserver is Present and remaining all Not Present. As shown in snap
Also in OPC wizard group creation , I received error as
Kindly Tell me what is wrong with me . Please if possible provide me detail solution about this problem.
Regards
(2,983 Views)
Zalmay,
Are you trying to conect to the DAQ OPC Server on your computer?  If that's the case, then you have to install the DAQ OPC Server locally on your computer.  I don't see it under 'My Computer' in the screenshot.
Or, are you trying to access it over the network?  Computer "JAFRI" seems to have it installed.  If you're trying to access this remote OPC Server, then you're in for some adventure.  Configuring remote OPC is not the easiest thing to do, and it's not fun either.  In any case, you will want to first make sure it works locally on machine JAFRI.  Run the Server Explorer there and see if you can communicate with it locally.
Good luck!
-Khalid
(2,977 Views)
