Problem in "replace array subset"
Dear all,
After I initilized an array, I want to use a for loop to give my data to the array, However,  only  the last row of the original array  was replaced,
I don't know understand why the first, second , third row was not replaced.   Anybody can help me? thanks a lot!
It is LabView 7.1.
Message Edited by hbin on 03-17-2006 08:41 PM
(2,796 Views)
          would you help to save your sample to labVIEW7.0 ? that I can help to view it.
________________________________________________________
Try to make everything Automatic
(2,788 Views)
You need to use a shift register. 🙂
Do some execution highlighting and you will see that with each iteration of the big loop you'll start out with the virgin array from the input tunnel on the top.
A shift register uses the array modified from the previous iteration. See if this makes sense to you.
(2,784 Views)
Altenbach, thank you so muchSmiley Very Happy
(2,780 Views)
