run event structure on startup
i have an event structure in a while loop.
when I run the vi i wish to run one of the events 1 time without a user input.
can this be done?? and if so how??
(3,225 Views)
Is this event tied to a front panel control? If so you can use the "Value (Signaling)" property, like this:
Message Edited by smercurio_fc on 03-17-200605:37 PM
(3,216 Views)
i tried what you suggested but it did not work for me i am including a sample vi to show what basically i have now.
(3,211 Views)
If you aren't going to use timeout event, you can use it for your example.  See attached vi.
George Zou
George Zou
(3,205 Views)
This does not work with latch action booleans, you need to fake latch action with a switch action and a local variable. The attached modification show a working version of your VI.
Of course I typically prefer a solution similar to George's.
The need for a generic "first run" event has been discussed before, see my example and discussion in this old thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=108599#M108599
Message Edited by altenbach on 03-17-2006 08:20 PM
(3,199 Views)
