DAQ and Coriolis Flow Meter
Hey,
Can someone help me... I need to hook up a Coriolis Flow Meter with the Transmitter IFT9701 to the NI-DAQ - FP1000 but I can't find the wiring diagram.
There are just three wires coming out of the transmitter (red, black and plain) and gives an output of 19.8 volts on a multimeter.
Also, If you have any VIs or know where they are to find the flow rate measured my the flow meter, kindly send me the link or the file to saravarad@gmail.com
Thanks in advance!!
Have a great day!
Saranathan
(4,071 Views)
-- What does "plain" mean - do you mean uninsulated?
If so, I would guess a 4-20 mA output.
That's meaningless unless you tell us if and how it's powered, and what resistor you used to measure.
Did you look up the specs?
It is indeed a 4-20 mA output.
Steve Bird
Culverson.com
LinkedIn
(4,058 Views)
FYI, you can find the datasheet at:
http://www.emersonprocess.com/Micromotion/products/transmitters-IFT9701.html
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(4,048 Views)
