DAQ and Synchronization
Hello!
   Now I want to write programs torealize  signal acquisition、signal processing、 contours displaying(using Intensity graph), all these modulus are finished respectively.  But the question is how to realize the synchronization among all these modulus?  The processing and displaying modulus runtimes are longer than theacquisition modulus.
Message 1 of 10
(5,786 Views)
Information is not sufficient enough to help
What is the need of synchronizing the processing and displaying module along with acquisition?
What is the data size that needs to be processed?
What is the loop rate at present in which the processing and displaying module takes more time than the acquisition module?
Vijay.
Message 2 of 10
(5,753 Views)
Than you for your reply.
   I sorry that all the "modulus" above should be "modules".
  First process is data acquisition, the sample rate is 100Msamples/M and the sampling time 50us,that is, 5000 sampling points. The DAQ interval is selectable(500ms,or longer that 500ms). Then the second process is signal processing (like filter, FFT ) and then generate a blocky rectangles of color. These two modules all cost longer  than 1s respectively.
My English is poor ,so I attached a picture.
Message 3 of 10
(5,719 Views)
I guess you are acquiring->Processing-> displaying in a single while loop sequentially otherwise 5000 sample processing should not consume 1s as you described unless you have very bad computer.
One option is split the acquisition and processing & displaying to two different while loops. One while loop for acquiring and another one for Processing and displaying. Use the queue to transfer the data from acquisition loop to processing and displaying loop.
Hope this helps.
Kindly post your source code to understand and help better.
Vijay.
Message 4 of 10
(5,690 Views)
    Now what I am using is just the method that split the  two different while loops and  use the queue. But  the question is the processing &displaying loop really takes more time that the acquisition loop. I have used the Filter—FFT—Matlab script(I think it's really  time-consuming ,right or wrong? ) in the precessing module.
     the problem of  the runtime above maybe OK while I don't need very precise synchronization. But one thing that I really cannot bear is that the processing &displaying loop always start later that the acquisition loop. when the acquisition loop finished the signal acquisition of a point, the displaying loop had just finished the diaplaying of points  before the acquisiton point.  So the non-sync makes me or users  feel very  confused. Do you know why? Did  the  reading/ writing speed difference cause this phenomenon?  If it's the spped caused the non-sync,Does that mean I cannot set a high acquisition speed?
   Besides, I have an idea thatsolve the the processing &displaying loop runtime problem.  I can  split the processing&dispalying module into several modules, and use the synchronization functions. In this case, the queue functions cannot be used because the one element in the queue can just be dequeued by once,not dequeued by all the module loops,am I right?
Hope you can understand.
 Carrot
Message 5 of 10
(5,680 Views)
What I understood is that you are already having two loops, one for acquiring and another for processing and displaying.
Why don’t you try using LabVIEW inbuilt FFT VI instead of the Matlab script (which is taking more time).
I don’t think you have any other solution other than optimizing the FFT part since that is taking more time. Even splitting processing and displaying may not help much.
Message 6 of 10
(5,673 Views)
Hi
   Thank you
   the Matlab Script is not for FFT but for  some non-destructive detections, and I used the  LabVIEW inbuilt  VI for FFT.  Besides I know the script will be a big trouble when generate the EXE file,but this is the core of our program.  Do you have other advises?
   Thank you very much.
  Carrot
Message 7 of 10
(5,667 Views)
One way is to rewrite the Matlab Script in LabVIEW. Since it is NDT, kindly refer below link it may be useful.
http://www.ni.com/example/28618/en/
Otherwise, I don’t think there are any solutions.
Vijay.
Message 8 of 10
(5,662 Views)
 Your advises will help me a lot
Carrot
Message 9 of 10
(5,657 Views)
  Sorry for disturbing you again.
 I have just modified my source code and I found a error in my Matlab script. Now the acquisition·module and the processing&displaying module are nearly the same runtime. But there is a question that when using the queue functions the processing&displaying loop always start later than the acquisiton module,the difference is one loop. I think it's caused by queue itself. So I wonder Is there a method to let the two loops sart at the same time?
Best regards
 Carrot
Message 10 of 10
(5,643 Views)
