PLC Communication with LabVIEW over Ethernet IP
HI ,
Could any one let know if there is any documentation on using Ethernet IP drivers to PLC.
I found this NI's own drivers at
https://www.ni.com/en-us/shop/product/ni-industrial-communications-for-ethernet-ip.html
would to good to know if there are good open alternatives to this .
The only one that was found was on github
ref : https://github.com/sivamgr/LabVIEW_EtherNET_IP
however there is minimal documentation to them.
Being a PLC beginner with a descent exposure to LabVIEW would be tricky to use these drivers.
As an ametuer like me , would be great if some one could just let me know how these drivers can be used to control PLC IO's.
I am Currently using micrologix 1400 PLC from Allen Bradley
Sundar.
(4,974 Views)
micrologix 1400 support MODBUS.
You can go through these links  NI Modbus Library for LabVIEW or you can use DSC.
(4,947 Views)
