How to change independently the property of each element in an array ?
Dear all
I have an array of cluster and the size of this array is defined in the front panel by the user. Is it possible to change independently the property of each element in an array. For exemple if the cluster contains a fill slide, I would like to have a different color for each array element. Is it possible? or do you have any idea how to do it ?
 thanks by advance
regards
mnemo15
(3,394 Views)
@mnemo15 wrote:
Dear all
 thanks by advance
regards
mnemo15
No can do.  The only thing that can be different between elements of an array are the values they hold.
Bill
CLD
(Mid-Level minion.)
(3,390 Views)
billko is right.  This question is asked frequently, too.
What you can do is use an array of clusters which contain the data you want and something else you can color.  I've made a Color Box indicator with a numeric on top of it.
Jim
(3,375 Views)
