DAQ assistant - error when applying a calibration
My situation is simple. I get the pressure from a pressure sensor.
It returns 0...10 V for a -1...6 bar pressure
I just open the DAQ assistant (input => voltage) and returns the value. I set Continuous Values because I want to have the continous values. I set 100 Hz because I don't need so much values every second (and also 1000 Hz bug).
It works 100% fine.
Problem is : it's not calibrated perfectly. So I use the calibration. I have small differences. I attached the picture. But when I use the calibration I have the error (image attached). If I unclick "enable calibration" (meaning desactive it), it works.
I set from 0 to 10 V, what my sensor delivers.
Any idea what this is ? "specified value is smaller than the minimum value" "corresponding value : 10"
doesn't make any sense to me.... thanks so much if someone can help !!
(1,342 Views)
Your Uncalibrated value for the Reference of 8.8 is 10.126.  That is higher than 10.
(1,322 Views)
