DAQ assistant is missing a data terminal
The DAQ assistant is no where to be found on my computer.  I've instaled the last DAQmx version 9.2.2 but unable to see DAQ assistant.  My device is a PCI 6220 connected to BNC 2120. What's going on.  All I'm trying to do is measure a voltage from a LED optical switch.
Message 11 of 12
(1,079 Views)
Like I said in your other post on this, look at the driver compatability list. You downloaded the wrong drivers. You are using 8.2 LV
https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
Alan
Message 12 of 12
(1,072 Views)
