DAQ assistant is not recording data when case structure is false
Accepted by topic author tousif54
Ah.  The simple fix is to wire a TRUE to the AutoReset input on the Elapsed Time.  Sorry, I missed that.
Message 11 of 30
(2,196 Views)
Thank you soooooooooooooooooooo much my friend. Worked like a charm. Can I marry your brain? rignt now.  Smiley Tongue
Message 12 of 30
(2,192 Views)
Sorry, it is already taken.
Message 13 of 30
(2,157 Views)
Having problem again. Smiley Frustrated I am setting on-time and off-time value as 900sec (15 min). But, after the experiment it seems that it remains on/off 2-3 mins longer. Do you have any solution to this problem? Thanks.
Message 14 of 30
(2,137 Views)
Post your latest VI.
Message 15 of 30
(2,133 Views)
Message 16 of 30
(2,127 Views)
I can't see any reason in your code why it would run 2-3 minutes longer.
Message 17 of 30
(2,122 Views)
How are you measuring this?  Is it just that the VI does not end once the On/Off sequence is done?
Message 18 of 30
(2,109 Views)
Nope. The progam is running for one and half hours. So, 3 on-off sequences (each on - 15 min and each off- 15 min). And it seems each on and off sequence taking longer that 15 min from the beginning.
Message 19 of 30
(2,103 Views)
The code you attached should give you 15 minute intervals as long as you enter 900 into both controls.  I can't see why it wouldn't.
You'll need to put some features in your code to log exactly when the changes occur.  "It seems" is not quite as definitive as "I know".
If you use shorter times such as 5 minutes, does it "seem" to take 1 minute longer than it should?
Message 20 of 30
(2,096 Views)
