DAQ assistant not working on Lavbiew version 2023
Can anyone tell me why the daq assistant is not working on labview version 2023?
What to do for getting it working?
Thanks in advance.
Patrick
(1,408 Views)
Have you installed LabView correctly? That would be my first guess.
(1,377 Views)
Most of us will recommend you avoid DAQ Assistant and use the DAQmx API.
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
Use shipping examples at Help >> Find Examples >> Hardware Input and Output >> DAQmx
https://tmesystems.net/
(1,366 Views)
See the Known Issues here:
https://www.ni.com/en/support/documentation/bugs/23/labview-2023-q3-bug-fixes.html
Just of it, Install LabVIEW 2021 SP1 (you don't need to active it, just the dev environment needs to be installed) and then it will work.
(1,306 Views)
