DAQ assistant scaling for different tasks
Is there a way you can have the user select different custom scales (via the front panel) for different tasks in a single DAQ assistant? An example might be different calibration curves for different instruments, all of which were set up in a single DAQ assistant.
(2,307 Views)
Hi jjd,
once you use plain DAQmx functions instead of the DAQAssistent you can implement anything you like!
(Search for an appnote about "10 daqmx functions"…)
(2,283 Views)
