DAQ assistant sync
I'm launching a website webshaker.ucsd.edu and I'm having trouble with LabVIEW's DAQ assistant.
  • When I run the VI manually, it seems to sync the DAQ input and DAQ output just fine. But when it's run continously, they fall out of sync.
  • Sometimes the outputs don't show. If I run the same inputs a second time, the output shows up just fine.
Thanks for the help
(3,876 Views)
1. You should NOT use the Run Continuous function.  That is a debug tool, not a way to properly run your code.  If you should be constantly sending and reading data, then your code should be inside of a loop.
2. You really should not be using the DAQ Assistant here.  You are trying to sychronize clocks which is an advanced thing that you should be doing with the real DAQmx API.
(3,853 Views)
I'm not too familiar with the NI-DAXmx functions. what's the best way to rewrite this with the DAQ function nodes?
(3,837 Views)
Read this excellent White Paper.
Bob Schor
(3,827 Views)
