how to create a status column in table
hello everybody
i am trying to create a status column in table in frontview panel. I have attached some image with it to make it clear what i want to say.plz tell me how to create the active status column in the table.
 i want to make it show green for safety stock and red for below safety stock.
Message 1 of 15
(5,003 Views)
What do you have so far in terms of your LabVIEW Front Panel?
You can do what you're trying to do with an array of clusters. The cluster in the array could have a boolean that turns green on True and red on False, or you could even do it with colorboxes:
Cheers
Message 2 of 15
(4,997 Views)
You can use a multicolumn listbox rather than a table.  This control allows you to select an item symbol.  There is not a huge selection of symbols to choose from so you will most likely want to add a custom symbol or two.
http://digital.ni.com/public.nsf/allkb/1AB08615E1FA73E8862574C2003806D5
aputman
Message 3 of 15
(4,975 Views)
Try this.
Message 4 of 15
(4,931 Views)
hlo paul i cant open the vi because that is of 14 version and i am using 13.can you send me the screen shot please.
thank you
Message 5 of 15
(4,893 Views)
Here it is for LV13
Message 6 of 15
(4,852 Views)
@paul_cardinale wrote:
Here it is for LV13
hi paul
Sorry ,i couldn't get what this vi is doing.what i want to do may be clear by the image of my vi.
i have attach image of vi in whis i have a table and in that table i want to create the status column which 111.JPGact like indicator.see..please suggest me any solution like this .so that when ever somebody add the item in the list  a new indicator row generated for itself.
thankyou.
Message 7 of 15
(4,828 Views)
I don't think you can get the LEDs as such, but you can color the background of that cell according to Status.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 15
(4,800 Views)
ya  i know that . BUT the problem is that the status keep on chaning so i cant keep it fixed.any alternate solution?
Message 9 of 15
(4,797 Views)
You can change the color of the background of a cell while your program is running
I do that all the time, to tell the user the status.
Message 10 of 15
(4,792 Views)
