DAQ assistant
I am trying to study a RC transient circuit using DAQ 6009 card but having some problems with DAQ assistant settings.
I basically want 2 inputs from the user :the voltage one of the port will generate and
the number of samples another port will read at a pre defined frequency .
The frequency can be constant but the user should have option to change the voltage applied and the total number of samples read.
Although i got the DAQ assistant right for Voltage I cant get the settings right for input DAQ assistant i.e for the number of saples to read(It will read voltage at one of the points in circuit.
Also is there any way that the values DAQ assistants read are stored in a database or exported to MS excel ????
Plz help.
(4,202 Views)
What exactly is your problem with setting number of samples? There's an input on the DAQ Assistant for this so all you have to do is connect a control to it.
Yes, there are ways to write to a database or Excel spreadsheet. Without any additional toolkits, you can write to a tab or comma separated text file that Excel can read. Write to Measurement File would seem to be your first choice if you are using the DAQ Assistant and Express VIs and don't want to do much programming.
Attaching what you have written so far will help you get a more detailed answer.
(4,195 Views)
actually the problem is now face is with data types of source and sink
they simply dont match.i have attached the vi.some please point out the error
(4,166 Views)
Nothing is attached. Do not select Preview. That will lose the attachment.
(4,159 Views)
sry the file wasnt attached the first time ^
(4,154 Views)
