DAQ with PCI/DSP4 (Physical Acoustics)
Hi there,
is there anybody experienced in using
a PCI/DSP4 from Physical Acoustics?
(3,708 Views)
Hello;
Are you trying to use a NI DAQ board in conhunction with the PCI/DSP?
If that is the case, could you provide us more information about that hardware?
Regards
Filipe A.
(3,708 Views)
A Labview application on one computer
controls the experiment and the PCI/DISP-4-board
(which gathers the information) is located at another one.
I have to stop the experiment if the signal rises above a certain level.
The software of the DISP-board
doesnt provide TCP/IP connectivity, so my idea
was to read out the board with Labview.
Are there probably predefined modules?
(3,708 Views)
(3,708 Views)
Hi Mario Sikora,
Have you succeeded in doing so?
I have almost similar requirements. I would like to control the PCI/DSP4 card and customize my acoustic applications using LabVIEW. I went through PAC's website and find out that there are a LabVIEW and Windows DLL drivers for it (http://www.pacndt.com/index.aspx?go=products&focus=/multichannel/disp.htm). However, when I contact PAC's local agent here (Malaysia), they told me to look elsewhere!!! Does anybody know where can I get this driver from?
Also, has anybody succeed in doing this before?
Thanks.
Shazlan
(3,500 Views)
Hi Lan,
This thread is a bit old, so I am not sure if the original poster will ever see this.  I did do some searching, and I think I came across the same link as you did on the PAC site, that explictly says for LabVIEW drivers to contact them.  I was unable to locate the drivers myself.  I would suggest contacting them again, and let them know their website says they have them.
If find anything here, I will be sure to let you know.
Kevin H
WSN/Wireless DAQ Product Support Engineer
(3,459 Views)
