DAQ write+read analog channels
Accepted by topic author Nicku
NickU,
The problem is that bus powered USB M Series devices do not support the 'Counter Output Event'.  If you open DAQmx Create Timing Source (Frequency).vi, you'll see that this is what it is attempting to do.  I don't believe that you'll be able to use a counter on your 6211 as a timing source for your timed loop.
Dan
Message 11 of 11
(942 Views)
